.sid to .dwg
.sid to .dwg
.sid to .dwg
I have a file from a surveyor that is a 20gb .sid file. I would like to open it in AutoCAD LT. Can I do this? I also have the .sdw .sid.xml  .sid.aux.xml do I need these too?
n_bartholomew
Hi Natalie,
Unfortunately Autocad LT cannot handle SID files.
See the link here for more details - https://forums.autodesk.com/t5/autocad-lt-forum/sid-file/td-p/2537367
That being said, Civil 3D can (sort of).
Information at tthis link may help you, otherwise try searching the forums here, or through Google.
https://forums.autodesk.com/t5/autocad-map-3d-forum/insert-sid-4th-generation-file/td-p/8310194
ChicagoLooper
Have you tried Feature Data Object Connection (FDO)?
First, set your modelspace coordinate system. Second, switch to Planning and Analysis workspace. Then go to Home tab=>data panel=>Connect icon.
In the Data Connect palette, go to Add Raster Image=>Image icon=>Browse to and select MrSID file=>Open=>Connect=>Add to Map (be patient, it may take a few seconds, or more).
1-Data Connect palette=>Image icon.1-Data Connect palette=>Image icon.2-Browse to and select MrSID file=>Open=>Connect=>Add to Map.2-Browse to and select MrSID file=>Open=>Connect=>Add to Map.3-Alternatively you may use MAPIINSERT.3-Alternatively you may use MAPIINSERT.
You can also use MAPIINSERT command. Insert tab=>Image panel=>Image icon.
Chicagolooper
