SHP Import / Export tool - Export Bug
CivilFlow
Advisor Advisor
CivilFlow
I am seeing an issue when using the 2023 SHP Import / Export Tool Export functionality.  The tool works for Property Set data exports fine, but when setting up the export there is an option to send out C3D cogo point or feature line property data out to shp.  The problem is it is sending out data rounded to the nearest whole number.  This is obviously problematic so I am hopeful the C3D Development team can take note of this issue and fix with next update.
The snip below shows a C3D point that was exported to shp using the Shp Import / Export Tool and what the data looks like in ArcGIS Pro.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
TerryDotson
... the C3D Development team can take note of this issue and fix with next update.
That problem was also reported 534 days ago.  A quick export test dropped into QGIS indicates Integer fields are being used.
CivilFlow
thanks @TerryDotson !
Michael M. Carlson
CADD Manager
