Hi @kwilson88PV7
Are you trying to redraw an existing shape?
Or are you trying to add a NEW shape to an existing shapefile?
If you are trying to change the outline of an existing parcel then CHECK-OUT the feature so you can 'edit' the existing outline. You you want to do an edit so it takes conforms to the new shape. In this case do NOT delete the existing parcel--just revise (edit) the existing outline. Be sure to check-in the feature after completing the edit. This might be (or might not be) tricky if the new outline has many vertices.
If you want to keep the existing parcels and want to ADD a brand new parcel then do this:
<<The following workflow assumes you already know how to add your shapefile to modelspace and that you are familiar with using the Map Task Pane.>>
To begin, change your workspace from Civil 3D to Planning and Analysis. Next, make a copy of your shapefile.
<<You should make a copy so you'll still have the original shapefile. If you make too many mistakes in your copied version, you can delete the copy and go back to the original.>>
Here's how to do add. Follow the steps.
1. Open a new drawing and ADD your existing Parcel shapefile ( refer to blue) as a Feature Data Object (FDO). Next, manually create a new parcel so you can add it to the existing shapefile. Use the AutoCAD pline command (polyline) to draw the new parcel. Make this new parcel a Closed Polygon (refer to red).
Image-1
2. In the Map task Pane, right-click the parcel shapefile=>New Feature from Geometry=>Continue to step #3.
Image-2
3. Continued from #2, using your cursor and click on the red polygon=>then YES to delete the red polygon.
<<You won't need the red polygon after you have clicked on it.>>
Image-3
4. This indicates the new parcel (the NEW geometry) has been ADDED to the existing shapefile.
Image-4
<<After step #3, your new parcel will be NEW geometry and look like Image #4 and the NEW geometry has just been added to the existing shapefile.>>
5. Next, you'll add the attributes manually. Open the Table View and over write each <Null> with the correct data. The PENCIL icon in the table's far left column indicates the shapefile has been CHECKED OUT. When your shapefile is Checked Out, it means the database is in EDIT mode. The shapefile must be checked out to perform any over writes.
Image-5
<<If you don't see the Pencil icon in the left column, you'll need to click the Check OUT icon. Highlight (make blue) the new data row in the Table then go to the Ribbon=>Feature Edit tab=>Edit Set panel=>Check Out icon. The Pencil icon must appear on the left to perform over writes.>>
6. After filling in the correct values in the Table, highlight the row so it's blue=>Click the CHECK IN icon to save your new data in the Table (which is the shapefile's database). The Pencil icon will go away AFTER you have clicked Check In.
Image-6
<<If you forget to Check-In your data and try to close down the drawing, you'll be asked whether you want to perform a Check-In prior to exiting. Don't forget to click Check-In. If you don't Check-In, then your changes won't be saved.>>
Chicagolooper
