SHOW PROJECTED PIPE (SECTION VIEW) IN PROFILE WHEN NOT ACTUALLY CROSSING
M!chelle
M!chelle
Is it possible to show a projected pipe section?  I have two crossing profile/alignments coming together perpendicular to each other.  When I draw parts in profile it just gives me a straight line and I want to see the projected section view.  I've tried to override styles in the profile view properties, adjust every  pipe style setting, and am getting nowhere.  Is this even possible and if so, how?
Mike.M.Carlson
If it isn't crossing the alignment, it won't show up correctly.  An easy work-a-round is to just create another pipe at the end of the "real" pipe (with start/end inverts the same as the invert that will be shown.  Then add this new pipe to the profile view you want.  The key here is to have a plan pipe style for this pipe only that is set to "no display" or "no-plot" for plan view perspective, but will show the "crossing" style in "profile" mode.  Not ideal I realize, but it will get you what you need.  Curious to see if others have a better work-a-round.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
M!chelle
Well... am happy to hear it's not something I'm fumbling over and missing.  I think in this scenario, it's likely best to just draw the ellipse in the profile (since I already have the vertical line showing) instead of maintaining two pipes.  Am curious to hear other workarounds as well - thank you for your help!  Will come back and accept as solution if no other responses.
be careful - the line that shows up in the profile view is likely one end of the pipe to the other as seen from the end (from the other alignment). You'll want to draw your ellipse from the end closest to the other alignment and base it on pipe size, not the line except for the appropriate end.
I'd probably go with what @Mike.M.Carlson  suggested - add a fake pipe from the end of the "real" pipe that crosses the other alignment, elevation at both ends of the fake pipe the same as the end of the real pipe closest to the other alignment (unless you want to project the slope of the real pipe), make it no display in plan view and crossing style in profile view. Voila - an accurate ellipse representing the crossing of the fake pipe.
It's harder to explain than it is to do.
M!chelle
Yes, I know what you are saying and understand the two pipe ends (four pipe borders) are showing within that one represented line skew.
troma
If you want one end or the other to show up, I would use a structure.
Structure should be at the end of the pipe.
You can make a structure style that doesn't show up in plan view, and in profile view only displays "Structure Pipe Outlines" and nothing else.
Then, draw your structure in profile view.
Make sure you don't draw the pipe in the profile view. If you draw the pipe, the "Structure Pipe Outlines" will not display in the same profile view.
Mark Green
Working on Civil 3D in Canada
lynn_zhang
Hello @M!chelle ,
Just checking to see if your problem has been solved. Have you tried the suggestion above from @troma ? Let us know if it works.
Lynn Zhang
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
