Hi everyone,
Thank you in advance for your help.
I received the pre-cal plan from the engineer, and I’m a bit uncertain about how to apply alignment to it. I apologize for my limited understanding of alignment. Since I already have the segment lengths for the lots, I'm wondering why alignment is still necessary in this context.
I noticed that under the Annotate tab, there's an option to add tables for parcels, specifically using the "Add Area" function. I was able to create a Parcel table that displays the Parcel number, Area, Perimeter, and Segment Lengths (all lengths in one cell as shown in image).
My goal is to export an Excel table with "width of lot" and "depth of lot" in separate cells. Referring to the image, the table I want would be Parcel number in one column, Area in one column, width of parcel in one column, and depth of parcel in one column.
Would the best approach be to draw alignments manually, or should I use the current Parcel table and then manually separate the segment lengths into a width column and depth column in Excel? I’m working with around 1000 lots.
I’ve attached the original pre-cal plan from the engineer (no centerline for building alignment), the parcel plan I created (with lot segment label), and the corresponding Parcel table (with all segments in the same cell).
Thanks again for your assistance.
