SHOW OR EXTRACT CONTOUR LINES FROM A GRID SURFACE
junkins
Message 1 of 25
junkins
C3D NOOBIE.
I'm working through Civil 3d and have utilzed the Autodesk RECAP to convert some laz files to rcp.
Then uploaded the cloud file into C3D to create a DEM using mapcreatepcsurface.
I end up with this nice grid surface of the area, but cannot figure out how to extract or actuate the contour lines.
Been searching videos on line for similar subject, but maybe I'm just trying to get something that is not there.
I know in corridor it can be done and extracted, but for some reason this is evading me.
Thank you in advance for any info out there.
CJ
Accepted solutions (3)
Replies (24)
Message 21 of 25
TerryDotson
Glad to see you got your project worked out.  We added notes about the blocking and related things to the blog post.  We added the width height thickness to the label and it zooms to extents of all LAS/LAZ files selected when it's done drawing them (download again if you need these things).  In case anybody missed it, the rectangle has thickness in 3D to shows the elevation extents.
Message 22 of 25
junkins
I passed the info for your file sets to this posting:
Displaying contours from LIDAR point clouds
by Mark.
Looked to me like he was having similar issues. Hope you don't mind. Maybe you can chime in there.
Thanks again,
Claude
Message 23 of 25
cromo23
What I dont get it.
I've recently HAD to upgrade to 2018 because of file format issues.
Now I cant import LAS files like I use to, because . . . . . . it was broken?
Do I need to install a 3rd party program now to get contours from my LAS files I've has for years?
Message 24 of 25
TerryDotson
If it's any comfort, that developer has been in business nearly as long as Autodesk (30 years), has been a Autodesk Registered Developer (over 25 years) and the program is free.
Message 25 of 25
Hey
Sorry for replying so late, I actually want to ask a question. I used Recap to convert the point cloud (.LAS) file to a .RCS file. I successfully pulled it into C3D and created a surface from it. My question is how do I switch off all the millions of points, since it doesn't seem like the point cloud has a display option anymore and you also can't select all to move it so a layer and switch it off. Any solution?
Thanks!
