Civil 3D Forum
Show me some of your drawings
4 REPLIES 4
m_kingdon
857 Views, 4 Replies
Hi all,
I am curious to know what the work of other users here looks like.  I have only used Civil 3D since I moved to Auckland, New Zealand and I’d like to broaden my horizons and see what more experienced users produce.
If possible, could you upload some examples?  I’d recommend redacting out client and location information.
Or point me in the direction of some online sources.
Printed PDFs converted to jpgs would be much preferred.
Thanks, here is an example of a recent project I worked on.
Title pageTitle page100 Existing Site100 Existing Site101 - Existing Site Cross section101 - Existing Site Cross section200 - Proposed Site200 - Proposed Site201 - Proposed Site Cross section201 - Proposed Site Cross section205 - Cut and Fill205 - Cut and Fill210 - Retaining Wall Plan210 - Retaining Wall Plan211 - Retaining Wall Longsection211 - Retaining Wall Longsection220 - Erosion and Sediment Control Plan220 - Erosion and Sediment Control Plan300 - Roading Plan300 - Roading Plan310 - Roading Longsection310 - Roading Longsection315 - Roading Cross Section (typical)315 - Roading Cross Section (typical)400 - Stormwater Plan400 - Stormwater PlanStormwater LongsectionStormwater LongsectionThe model in Civil 3DThe model in Civil 3DModel in InfraworksModel in Infraworks
Mike Kingdon
Civil 3D Zealot
Labels (1)
4 REPLIES 4
ChrisRS
in reply to: m_kingdon
Excellent work, Mike.
I like the idea—kind of a virtual Civil 3d Refrigerator Door.
I would probably be too embarrassed to hang anything up.
I think you would be satisfied with images embedded in or attached to replies, not actual drawing files.
If this is so, you might consider editing the original post to clarify.
I am tagging in @lim.wendy to ask if something like this already exists. If not, maybe this post deserves to be pinned in the top section, at least for a while.
Christopher Stevens
Joe-Bouza
There is the break room forum... if it still exist. it deserves a spot here. I'm embarrassed too after seeing @m_kingdon  Mikes lol
Joe Bouza
alexRR6ZB
nice work m.kingdon. Appreciate the effort in infraworks. I've made some use of it but not to the same extent as you have. perhaps later. Not keen on posting work product but i attached a file containing the Proposed surface from the project i'm currently working on. 8 lot rural with floodplain infill and stormwater detention. keep up the good work.
cheers
JamesMaeding
Some surface modeling I just did at a mining site. Existing and proposed contours shown at 1 ft interval.
Portion of another job's surface, these are 5 ft contours:
I do most of the earthwork modeling for the company so have a hundred of these.
Then some utility modeling shown in Infraworks...
Yep, full wet and dry utils, trees, the works. The util models are done using in house software.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Rail Community
