Civil 3D Forum
Shifting layout tabs 2015 Civil3d SP2
18 REPLIES 18
Message 1 of 19
2575 Views, 18 Replies
There is a quick fix for SP2 2015 Autocad to take care of the layout tab shifting problem so many seem to be having.  I'm having the same problem with layout tabs involuntarily shifting after loading the SP2 for 2015 Civil 3d.  The quick fix for Autocad does not seem to load properly in Civil 3D.  Where can I find the quick fix for Civil 3D.  It is extremely annoying to constantly have to move layouts back to the proper order in a file consisting of at least 15 layouts.  Thank You.
18 REPLIES 18
Message 2 of 19
Alfred.NESWADBA
Where do you find SP2 for Civil 3D 2015? Never seen it and don't find it.
And with Civil 3D 2015 I have no shifting problem with layout tab's (but I also have not had it without SP).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 19
wfberry
in reply to: Alfred.NESWADBA
Alfred:
The only way I found it was to go to Autodesk Application Manager.  I do not believe that I ever had a notification.  I am not sure why I installed it, but I did it anyway.
Bill
Message 4 of 19
Alfred:
It showed up last week one day in my application manager so I loaded it.
Didn't see it on the subscription site for Civil 3d however. I had no
problems with shifting layout tabs until I loaded the SP2. The hotfix for
the same problem with 2015 Autocad SP2 solved the problem. I found
instructions on how to install it on the Autodesk forum. Hope that helps.
Garry M. Osborn
Engineering Technician
Marquardt Engineering, PLLC
gmosborn57@gmail.com
work phone: (918) 615-3511
cell phone: (918) 694-6612
Message 5 of 19
Alfred.NESWADBA
>> problems with shifting layout tabs until I loaded the SP2Well, as I don't have SP2 installed (for Civil 3D 2015) and I don't get an update-info from Autodesk Application Manager (even when I start the "search for updates" manually) I guess SP2 is withdrawed.
That also might be a reason why I haven't seen moved layout tab's yet.
- alfred -
Alfred NESWADBA
Message 6 of 19
Jeff_M
Alfred, perhaps SP2 wasn't released for your language version yet. I downloaded and installed it yesterday using the Application Manager.
Message 7 of 19
Alfred.NESWADBA
in reply to: Jeff_M
Hi Jeff,
Well, possible yes, but looking for the last years the service packs were not language dependent.
- alfred -
Alfred NESWADBA
Message 8 of 19
DarrenP
i uploaded it to my dropbox along with the read me for it
https://dl.dropboxusercontent.com/u/9777150/Civil%203d%202015%20SP%202.zip
DarrenP
Message 9 of 19
DarrenP
in reply to: DarrenP
the shifting layouts fix was released: http://knowledge.autodesk.com/support/autocad-civil-3d/downloads/caas/downloads/content/autodesk-C2-...
DarrenP
Message 10 of 19
Alfred.NESWADBA
Hi Darren,
thank you for uploading it, I'll first will read the readme and then decide to install it or not.
BECAUSE ... looking to the >>>Being Civil blog<<< the screenshot really says "AutoCAD Civil 3D 2015 English-US Locked ..." and that brings me back to Jeff's post about "not available for my language".
...download...download...download... 😉
OK, download finished, readme does not tell me anything about limited to english or to US, so I started the installation of SP2 and if finsihed without issues, Civil 3D started and seems to work well for a few minutes (and WMS is working).
Thx for uploading the SP! If there are any issues, I'll come back 😉
- alfred -
Alfred NESWADBA
Message 11 of 19
DarrenP
its been posted: http://knowledge.autodesk.com/support/autocad-civil-3d/downloads/caas/downloads/content/autodesk-C2-...
DarrenP
Message 12 of 19
I've wasted way too much time on this annoying defect.  I'm using Map3D 2015 here.  I had to copy the DLL into the Autocad 2015 program install directory as well as the Map3d program install directory to get it to work correctlly.  Not sure why, but it didn't work when I installed it just in the Map directory.
Poor customer support to release hotfixs that require the users go in and fiddle with renaming, copying, and installing program DLL's when they may not even have admin privledges, but whatever. Got it fixed now.
Message 13 of 19
I do have the same problem with my AUTOCAD Mechanical (architecture), does the hotfix that you uploaded will works with my version?
Tags (3)
Message 14 of 19
It should. Autodesk claims it works with Autocad and all it's verticals.
Message 15 of 19
Bless you Darren. This was driving me mad!
Message 16 of 19
Deshi10
This issue is persisting beyond SP2. I have installed SP3 and still experience the issue. I installed the hotfix and if I try to drag and move a layout tab it's an instant fatal error.
Has anyone discovered a solution to this?
Message 17 of 19
in reply to: Deshi10
Message 18 of 19
Deshi10
That is the hotfix I was refering to. Did you try to click and drag your tabs? When I do I get a fatal error.
All I did was swap the .dll file.
Message 19 of 19
I've applyied that hotfix a long time ago and it seemed to have work.  But now I'm having the same issue again running Map3d 2015 SP3... the tabs roam all over the place when swithching layouts again.   Probably no manual regression testing was done for this bug?  Whatever, I guess we'll just have to live with another fun ADSK bug to drive us all nuts. 🙂
Rail Community
