Civil 3D Forum
Sheet set is now empty
2 REPLIES 2
Cadd-mandu
167 Views, 2 Replies
I searched and did not find a solution to this issue so I decided to post to see if anyone could help.
I am working on a project started by someone else and initially the Sheet Set worked fine and all the sheets were visible. Then one day when I opened the drawings (sheet files) and the Sheet File Manager displayed as shown in the attached image. It sees the SS is there but does not populate the sheets. Other uses still see the sheet set as originally constituted but I cannot. I can still created for fields and reference the data in the SS but I cannot see it in the SSM.
Any thoughts are greatly appreciated.
Labels (1)
2 REPLIES 2
user181
in reply to: Cadd-mandu
Make sure you are on the Sheet List tab and not the Model Views tab
Cadd-mandu
in reply to: user181
Thanks! I didn't even notice the tab was switched. Just about drove me crazy. Much appreciated!
Rail Community
