Sheet Set Error using pagesetup override
I normally have my page setup and use publish to pdf with PUBLISHCOLLATE set to 1 this works fine.
However, Sometimes I want to publish using pagesetup override. This is when I don't want to use the default pagesetup for the layout. (Mainly when I want to make a pdf that uses a color pen file rather than a black and white pen file.) I may wan't to go back and forth between color and black and white.
The problem is:
If I have PUBLISHCOLLATE set to 0 and right click and select publish using page setup override I get individual pdfs as expected.
If I have PUBLISHCOLLATE set to 1 and right click and select publish using page setup override I get an error and no pdf is made.
I am using the same print driver in all situations DWG to PDF.pc3.
I have audited the used drawings and template from where the pagesetup is from.
Is there a fix for this?
Thanks, John
