Sharing data
Sharing data
Sharing data
Hi, how can I share every data in the C3D 2016? I found only sharing surfaces, alingment and profile shortcuts. C3d 2017 allows sharing corridors with helping shortcuts. But when I share surface of corrigor in C3D2016, i don't make corridor from surface. I'm looking for easy setting. So, Have you better cause of sharing data in the C3D 2016. Thank you
tcorey
In 2016 and below, Corridors cannot be shared through Data Shortcuts. They can be part of an Xreferenced drawing and accessed for sectioning from there.
I am not sure I understand what you mean when you say "...i don't make corridor from surface." Maybe you can outline your expected results and the steps you are taking.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
