Setup.exe file starts but not completes it
m_fernandezJS676
Observer Observer
m_fernandezJS676
Observer
Observer
How can I install my civil 3d with trial. I've downloaded the file and extracted it but it does not install. When I run It as a administrator the setup.exe file it stops .
matt_anderson_pe
At this point, something fails.  (obviously)
If you had support, Autodesk Support could provide a tool to fetch the files needed to diagnose the problem.
As it's a trial,  browse to the %TEMP% folder and look for the installation logs. As the Civil 3D trial is likely a streaming install - the executable will download the rest of the files as it installs. If that fails to launch, check your system against the requirements.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
