Setting Targets for Corridors without confusion
tpennerNXGJH
tpennerNXGJH
Hey all,
  I have to say the tool for setting corridor targets is a terrible bit of UI.  I can't tell which target is going where.
Here's what I'm looking at;
Unfortunately it doesn't explain which is being targeted because the descriptions are so vague.  It doesn't show chainage and it doesn't show on the plan or assembly which target is referring to where.
I'm trying to set the target for each side of the sidewalk.  Here's what I'm working with in Plan view
The bright green lines are the feature line targets.  If you have any tips or tricks to make this less of a headache I'd love to hear.  Thanks!
Thanks!
tcorey
Don't use Set All Targets. Set targets separately for each Region and your confusion level will be reduced significantly.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
m_kingdon
Two things I do to reduce the stress of corridor modeling:
1. Name your sub-assemblies.  One of those "you will thank me later" kind of tasks.
2. Use condition sub-assemblies and target polylines on specific layers. These act as a yes/no decision tree.
For example: is the orange polyline adjacent to the alignment?
Yes - use this branch of sub-assemblies
No - use the other branch of sub-assemblies
Using this technique massively reduces the need to split your corridors into multiple regions.
I hope these help!
Mike Kingdon
Civil 3D Zealot
tpennerNXGJH
Wow - you both rock - I never even thought of these.  They're so simple I don't know why I hadn't.  Thank you so much!
Jeew-m
This would also be handy when naming subassemblies.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
neilyj666
The corridor dialog box is probably the most poorly designed ever (although I'm led to believe it will be changing in future releases) and I use the tools that appear in the contextual ribbon.
Jeff Bartels has a good video on this workflow Simplifying Civil 3D Corridor Modeling using Contextual Tools - YouTube
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
