Set style component layer with code/dynamo?
Buzz0m
Buzz0m
I will be forced to manually go through a Civil3d Style template with a bunch of styles for all the objects. The issue is that I am supposed to convert all the style component layers to "0" so that when the drawing is exported the objects will actually end up on the layer that they were placed on and NOT on the layer of the style component.
Is there a efficient way of achieving this? I am dreading the thought of going through all the object types and styles. Not to mention the annotation styles.
Thanks in advance 🙂
- Frans
Sean_Fahey_10
Yes, dynamo will help you perform this task.
You will need the Camber Package to perform this.
rl_jackson
Simple solution
Style Component Find and Replace | Autodesk Civil 3D | Autodesk App Store
Rick Jackson
Survey CAD Technician VI
Buzz0m
Thank you for the awesome and quick replys! I think the better for me in this case would be the dynamo solution, but the Style Component find and replace functionality will definitely come to use later on! So very valuable pieces of information to me! Thank you @Sean_Fahey_10 and @rl_jackson !
