You know how if you're juggling several projects, or several parts of a project at the same time and you have to have 2 or more dwgs open at a time, AutoCAD will create tabs above your work drawing? Now you're trying to use a command such as MOVE where you need to select objects and then hit [enter] to confirm that selection to get to the next step of the command. But instead, nothing happens and AutoCAD is still letting you select more objects and you can't get it to progress. You can exit that command and try, try again, but the same thing keeps happening and you're just stuck. When this happens, visit one of your other tabs, probably the last one you visited before the glitch. You'll be greeted with a prompt of the last command you entered in that tab. If you exit that command, it will come up again, and again, and again, and again as many times as you attempted the command in the tab you were being glitched out of.
Basically, when you changed tabs, the software sorta changed tabs but is also still sorta in the other one. Fortunately, you are unable to confirm a command in either tab so you can't screw up the tab AutoCAD is herp derping around in. The work around is to just save the work in your current tab, close only it and reopen it. You don't have to restart all of AutoCAD just yet, but you might want to get to that as soon as you can. I'm not sure how something this elementary makes into a released version of the software. I really wish they'd do better.
