Select Shape File dialogue box on file open
dslocum
dslocum
Since upgrading to C3D2018 I'm getting multiple 'Select Shape File' dialogue boxes every time I open a file. No one else in the office is getting this. How can I solve this or at least suppress the dialogue boxes from appearing?
Replies (10)
BrianBenton
Do you mean for missing fonts? Can you post a screen shot of the error message?
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
dslocum
Capture.JPGHere's a screen shot of the dialogue box.
BrianBenton
It looks like it is looking for a missing font. Did you import DGN files? They will sometimes cause this to happen. You can set FONTALT to a SHX file and that should automatically replace missing fonts to what ever you set it to.
Brian C. Benton
dslocum
I already have ALTFONT set to simplex.shx and I still have to cancel out several of those messages on every file open. Any other ideas?
BrianBenton
There should be an option to replace or ignore this type of selection for the error message when it appears. Do what you want one time and it should do that every time.
Brian C. Benton
BrianBenton
You might be missing the SHX files on your workstation, that's why it can't find them. Or maybe your text styles are referencing missing shx file. Try to find out which text styles have missing shx files and replace them. Or its possible DGN files were imported and it is missing those shx file.
Brian C. Benton
dslocum
I checked all of the text styles and none are using the missing fonts. It's possible that I have a line type that uses these fonts. I'll check that and follow up. Thanks for you help so far.
BrianBenton
I had a project once where we imported Microstation files and it screwed up our shape files on that project for a long time. It was annoying to say the least
Brian C. Benton
I had that happen where it looked for a shx file and the file was in the folder it opened up when it couldn't find it. No clue why. I finally found an instance of the shx in a linetype definition (in the template) that once I deleted the message went away. I know you can check the box to Do This Every Time, but that doesn't solve the problem, just hides it.
you might try this lsp routine. I found it when researching the issue - I think it might even be from Autodesk. but it didn't really do much for me. DELSHAPE is the file and command to run :
;;;-------------------- START OF FILE ------------------------
;;; DESCRIPTION
;;; This routine deletes all shapes in the drawing
;;; that do not have a file definition.
;;; RUN
;;; -load this file and run the new command DELSHAPE
(defun c:delshape ()
  (setvar "CMDECHO" 0)
(setq n 0
  nshapes 0
  delete 0
(setq shapes (ssget "X" '((0 . "SHAPE")))) ;shapes
(setq shapes_name (ssget "X" (list (cons 0 "SHAPE") (cons 2 "*"))))
(if (/= shapes nil)
  (setq nshapes (sslength shapes))
) ; n. total de shapes
(if (and (= shapes_name nil) (/= shapes nil))
  (progn
    (while (< n nshapes)
  (setq entity (ssname shapes n))
  (entdel entity)
  (setq delete (+ 1 delete))
  (setq n (+ 1 n))
(while (and (< n nshapes) (/= shapes nil) (/= shapes_name nil))
  (if (or (= (ssmemb entity shapes_name) nil))
    (progn
  (entdel entity)
  (setq n (+ 1 n))   )
  (prin1 delete)
  (princ " shape(s) deleted\n")
  (command "_purge" "_sh" "" "_n")
) ;;---------------- END OF FILE --------------
Is there a path to the missing font files that is missing from your 2018 install but is in your previous version?
