Sections (Assemblies)
- Mute
- Permalink
- Report
Good morning, i'm trying to represent a trapezoidal section, but when i generate the assemblies, i notice some difeerences between the expected and obtained result.
I attached 2 images:
* The first one represents the typical section defined, wich behaces as it was generated from an 0.075m offset. The thickness of the cover is constant and the base of the channel is widened at the bottom to match with the cover of the slope.
*The second picture corresponds to the generated assembly, where the base is a rectangle instead of a trapeze. Althoug the covering of the slope up to the first berm is defined with a thickness of 0.075m, it materializes in 0.053m to coincide with the covering of the base. the Green line indicates the actual shape it should take.
Greetings.
