Section views won't update after the alignment has been changed.
Hi everyone,
I am still fairly new to AutoCAD and I am working in AutoCAD Civil 3D 2018.  My project is a cleanout for a assessment drain.  In my drawing, I have two surfaces-an existing ground surface and finished ground surface.  I have also created the alignment, corridor, and profile view.
My Problem: I created sample lines and then the multiple section views so I could come up with a volume that will be coming out of the drain.  After going through the section views, I noticed my alignment was off is some areas.  I then went and made the changes to the alignment in my drawing, but it would not update in my section views.  I then deleted the section views and re-created them, but it still gave my the same results as before like I hadn't even changed anything.  Does anyone know how I can fix this?
Thank you in advance!
Jeew-m
Did you rebuilt the corridor to update section views.?
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
