Section View
Section View
Message 1 of 8
Section View
When I adjust the levels the section for my corridor extends outside seating view, why?
Replies (7)
Message 2 of 8
"extents outside section view", why?
Message 3 of 8
BushW
Hello @Anonymous
Do you think you could possibly post the drawing? Thanks
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 4 of 8
Here you are!
Message 5 of 8
Hi, Did you have time to look at it? BR Akbar
Message 6 of 8
BushW
Hello @Anonymous
Yes, I was able to review your drawing. From my investigation, the in the section view properties the Clip Grid is not allowing you to clip the view corridor model.
I was able to adjust sample line so, that corridor will be cut off in the section view. Hope this helps!
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank for doing so, and I'm here to help.
Wendell Bush
Message 7 of 8
Japp...I should do the trick! But I never understand why that is a choice, of course you want to keep all profiles just inside the grid/section view! Thanks!
Message 8 of 8
BushW
Hello @Anonymous
I am glad to hear that it worked! If you ever have any problems in the future, I'll be here, and I'm happy to help.
Best Regards,
Wendell
Wendell Bush
