Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Section View Scale - Cross Section Sample Lines
6 REPLIES 6
oageng09
773 Views, 6 Replies
I used a 1:500 A0 scale. My model scale is 1:1000. To create multiple section views.
However, I am not happy with the scale, the cross sections are tiny, I'd like them to appear bigger.
Can anyone assist to fix this?
I tried this, didn't work
This is just vertical scale. Doesn't really work .
Thank you,
Labels (2)
6 REPLIES 6
ecfernandez
in reply to: oageng09
Hi @oageng09, welcome to the Autodesk Civil 3D forums. Just change the scale of the drawing to 1:500
Look, I have these sections in 1:200 scale
Now look at what happens if I change to scale 1:1000. The paper/sheet container gets bigger
You need to define the right scale for your sections. I personally use 1:200. Set the same scale you want for the sections for the entire drawing, and you'll see the sheet will become smaller, and once you update the section view group, they will rearrange by themselves.
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
oageng09
in reply to: ecfernandez
Hi @ecfernandez ,
Many thanks for the assistance and help images.
I implemented a 1:100 scale and the text is bigger (I am ignoring the changes to the alignment text scale).
The text is bigger but not the sheet view
Im using C3D 2016 (very old yes).
Not too sure what I'm doing wrong.
ecfernandez
Hi @oageng09, I recommend watching this video:
Link: 12 Creating Section Views in Civil 3D 2020 to 2022
Once you see it, you'll better understand section view creation, and you'll easily detect how to fix the template you are using so your section views appear according to your preference. If you have further questions during the process, don't hesitate to post again. I'll be more than happy to help you.
Best regards!
Camilo Fernández
LinkedIn
neilyj666
Remember that the text on cross sections is set to plotted mm so, for example, 3mm text on a 1:250 section would appear to be smaller than that on a 1:500 section and on a 1:1000 scale it would appear to be very big. However it is only bigger/smaller relative to the other detail on the sections - if you measure the text with a ruler it will be 3mm at all scales
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
oageng09
Hi @ecfernandez@neilyj666
Thank you much for the help. Turns out my scale was very much incorrect.
Resolved the edit scale list with Edit Scale missing
Then my crossections were stacking on top of each other (scale too small 1to100) Cross sections stacking on top of each other
I used a 1:250 scale, edited my cross section template  Cross section template
I think my issue is resolved
My model scale is 1:250
My viewport scale is also 1:250
ecfernandez
Hi @oageng09, it is good to know the issue was solved. Thanks for sharing it with us. Best regards, and have a good day
Camilo Fernández
LinkedIn
Rail Community
