Section View Layout/Drafting Buffers
getrekdent
2,963 次查看
2 条回复
1 条消息(共 3 条)
getrekdent
I have been fiddling with some basic section views trying to understand the way Civil 3D plots Section Views when using the "Create Multiple Views" command. I want to be able to utilize my entire sheet whenever possible, but Civil 3D keeps all of this whitespace between each Section View.
Is there a way to control this and set the horizontal and vertical buffers manually eg. 0mm, 0mm?
I've fiddled with the "Plot Rules":
Set the "Space between adjacent Section Views to 0:
Played with the "Plot area grid details", tried setting them smaller and larger... I want it to look uniform and professional but am having an issue accomplishing the correct spacing.
This image is all I am able to accomplish so far. Can anyone point me in the right direction?
I would like to have an output similar to this:preferred.JPG
BoXx ApeXx S3 Workstation - 64 GB Ram
i7 Overclocked to 5.1GHz - Nvidia Quadro P6000
0 个赞
已接受的解答 (1)
2,964 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
Jowennl
已接受的解答
Hi @getrekdent,
This is doable if you remove data bands, create new group plot, and update buffer settings offset. See images below to guide you.
1-new-plot.png1-new-plot.png2-edit CreateMultipleSectionView.png2-edit CreateMultipleSectionView.png3-test create mult xs.png3-test create mult xs.pngCheers,
Jowenn
3 条消息(共 3 条)
getrekdent
Jowennl, you're the man! Thanks a ton!
