Section view label style Editing
tonykhoury
Message 1 of 10
tonykhoury
I am trying to edit the section view label style in civil 3d but when i go to settings there is no "expressions" under the section label style.
I am trying to subtract -1' from the elevation. Does anyone know how to do it directly in the text component editor ? please see attached.
Tony
Replies (9)
Message 2 of 10
cwr-pae
The expression needs to be created in the settings tab of the prospector before it will show in the Label Style Editor.
Message 3 of 10
tonykhoury
I am aware, that i need to create an expression. However, there is no expression option in the settings for the section view labels.
Tony
Message 4 of 10
cwr-pae
What version? They show in 2017 (and I think 2015). Since you know where they should be (under each label type) you may need a install repair if they don't show up.
Message 5 of 10
cwr-pae
You should see this:
Message 6 of 10
tonykhoury
I have the same view, but under section view styles i dont have an "expression". if you expand it do you see
"expression"?
Message 7 of 10
Jeew-m
Dear Friend,
Can't you lower the surface on which section view label are related (or by creating a duplicate surface) by 1'. Then the labels will automatically shows what you need. However I don't know what is your exact need for lowering elevation and what extent this will help you.
Thanks.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 8 of 10
cwr-pae
Peek at it again, section view labels are expanded and do show expressions. View styles them selves have no label expressions.
Message 9 of 10
tonykhoury
Section view labels have expressions. However, if i create an expression here it will not show-up when i try to edit the "section view style" left or right vertical line text.
Message 10 of 10
tonykhoury
Section view labels have expressions. However, if i create an expression under labels, it will not show-up when i try to edit the "section view style" left or right vertical line text.
