Section View Invisible
vbogdanYLC3R
vbogdanYLC3R
hello, when i do Alignment - Sample Line - Section View sequence. it says Section View Created. But I don't see anything. It is empty. Could you help? Thank you!
nkiakas
Hi @vbogdanYLC3R
Can you give some more info?
From what you already shared i understand that you created an empty sample lines group, that's why you don't see anything inside the section view, but at least you should see grid, band etc. of the section view...
Or you created a sample line group without sampling inside any sources (surfaces of corridors...)
Regards
vbogdanYLC3R
Hello, thaks for getting back. I think  i figured it was on layer 0 which was turned off thats why i did not see anything..
tcorey
Layers!
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Type a product name
