Section Editor Code Set Style
Every time I go into Section Editor while working on my corridor I have to reset my Code Set Style Selection. Has anyone ran into this? Its not even like I am exiting and re entering the drawing, just the Section Editor. Is there a specific place C3D looks for that style when you enter the editor? Thanks
apweng
You need to modify the command settings.
From Settings tab of Toolspace, expand Corridors and Commands.
Modify the ViewEditCorridorSections command settings - and you will see you can set the default code set style there.
Andrew
Awsome I knew it was hiding somewhere. Thank You!
