SAC Help
SAC Help
I come back for SAC 🙂
I'm in a particular case, I have a very simple type profile (two points and a line) but I want to add a condition to apply a variation on the width.
It will be:
3 if I am in alignment
5 if I'm in curve
liniéaire interpolation between 3 and 5 if I'm in spiral
PS: the horizontal alignment is made (Alignment, spiral, curved)
Thank you in advance for your idea.
KMercier_C3D
The baseline.turndirection API function will return 0 if you are in a straight portion of the alignment but (to my knowledge) beyond that it can not differentiate if you are in a curve or a spiral and even if it could, it would not be able to provide the data necessary to interpolate for the spiral if you would also need to know where the spiral started and ended along the alignment.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
