SAC 2024/25/26 UI Issues.
jstrachan6F7KB
jstrachan6F7KB
My SAC's UI doesn't show some features, especially in the toolbox window.
Eg. the "Text"/"Display Text" does not show
In the Input/Output parameters window, selecting double/integer does not give a min/max option.
Is there a fix for this?
Regards
SoaresASBCAD
Yes, there is a fix, and this is not the expected behavior of Subassembly Composer (SAC).
The symptoms you describe:
  • "Text" / "Display Text" missing from the Toolbox
  • No Min/Max fields for Double or Integer parameters
usually indicate one of these issues:
1. SAC version mismatch (most common)
Make sure that your Subassembly Composer version exactly matches your Civil 3D version and update level.
For example:
  • Civil 3D 2026.1 → SAC 2026.1
  • Civil 3D 2025.2 → SAC 2025.2
Autodesk has documented several SAC issues caused by version mismatches after updates or reinstalls.
Check your versions:
  • In SAC: Help → About
  • In Civil 3D: About → Product Information
If they don't match, reinstall SAC from the same Civil 3D installation media/update.
ASoares
