Rotated viewport with raster image is washed out
I have a raster image in the background. The raster image resides in another file, which in turn is xref-ed into the main drawing.
The image plots properly when the viewport is at 0 deg, or rotated by full 90 Deg.
At any other rotation values, the image is washed out, when simply looking at the screen (rotated viewport looks darker, thus lighter when plotted).
There are no differences in viewport properties, other than the rotation.
The rotated viewport is washed out when using dwg to pdf built in plotter.
When plotting to Bluebeam, both viewports plot normally, but the file size increases 3.5 times.
When plotting with Microsoft Print to PDF, both viewports plot normally, but the file size double.
I could probably adjust Bluebeam and/or Microsoft Print to PDF settings, to reduce the file size. However, I would prefer to use built in plotter for several reasons.
How can I make the raster image in rotated viewport to print properly with DWG to PDF?
Thank you.
