Civil 3D Forum
Rotate pressure pipe fitting in profile view
1 REPLY 1
jayVVKFY
203 Views, 1 Reply
I am using Civil 3D 2022.
I have a tee fitting that indicates the connecting pipe has an allowable deflection of 5-degrees, but the actual deflection is 9-degrees. I'm pretty sure it's because the Tee fitting is horizontal, and the pipe profile (placed at a 3-ft depth using cut length offset style in the pipe run profile settings).
See attached screen shot images.
Is there any way to rotate the tee fitting in the profile view to align with the sloping pipe?
1 REPLY 1
rl_jackson
in reply to: jayVVKFY
I'm not totally groovy with Pressure Networks yet, but I've read a couple post (complaints) and solutions that recommend doing a 3DPL and converting it for the network when it gets a little hairy. Solution no workaround maybe.
Rick Jackson
Survey CAD Technician VI
Rail Community
