Road cross section from surfaces
geoferoze
geoferoze
I have two surfaces like Existing Ground surface, Design surface model and alignment of proposed roads. how to prepare road cross sections using these two surfaces and alignment in simple way.
Anyone! please give me step by step procedure in CAD Civil 3d.
Jeew-m
Hope this video will be a good start point.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Dear Friend, You need to design a corridor first, and then generate sample lines for the alignment you used as your corridor baseline. Then you want to create a section for the samole line(s). Here's the procedure:
--create an alignment
--pull a surface profile sampling your EG surface
--design a profile based on your sampled EG surface in the profile view( skip this if you have your proposed surface)
--create an assembly for your road section using subasembly( Ctrl+3) tools
--create your corridor using your alignment, your PROPOSED profile/surface, and your assembly
Then sample your corridor, EG surface, and proposed surface using " Sample Line" tools, at a desired station along your alignment. Now simply select the sample line, and select "Create Section" from the ribbon. Click yes on the prompts, and click on an empty space to put your section.
Hope it helps somehow.
geoferoze
Thanks for your response. Yes i draw sections with out road Assembly using finished ground surface. in this method, can i include other surface like Existing Ground levels Surface in the section view. so that i can compare cut & fill.
Please advise.
