Civil 3D Forum
Right click menu in Mtext will not allow new words to be added to dictionary
1 REPLY 1
224 Views, 1 Reply
Recently, C3D2014 was installed on my computer here at work (without regular AutoCAD 2014). When I want to add a word such as "HDPE" to my dictionary (which seems to be installed in the correct folder) nothing happens. I need to select the text then use the spell check panel from the ribbon to select the word. The File path is set correctly for the dictionary.
Is this a fix I need to make in the CUI? When I expand the menu lists available in the CUI, I don't see anything about the dictionary, although it appears in the menu when I right-click. Thanks.
1 REPLY 1
It looks as if using the Ribbon spell check "activated" the right-click menu. I now can add highlighted words to the dictionary.
Rail Community
