Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
remove an object from a selection set
How can I remove an object I just selected from a selection set?   I can't find the setting that allows this. Is it some combination of items check under the selection modes in the options menu?
tcorey
Hold Shift and select the object.
This will not work if AutoCAD Map image selection setting is on. See MAPIOPTIONS command, General tab. Turn off Shift+Left Click Image Select.
If you're inside a command, selecting objects, and at the Select Objects prompt, you can type R <enter> and you will be prompted to Remove Objects. This removes them from the selection set. To go back to adding to the selection set, type A <enter>.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Thanks, turning off the MAPIOPTION did the trick.
rharris83Z7U
Thank you!!! I've been looking for this for almost 3 weeks
