Realistic view shown as pixel for corridor link
ulgena
ulgena
Hi;
I have problem abaout Realistic view quality differences between link assigned render material and surface assigned render material.
I dont need to create surface to render and i only want to assign material to links and get realistic view of it. But when i make this, material's scale is not correct as you see in attached views. when i create surface and assign materials on it there is no problem. Have you been experience about this issue before?
tcorey
Which version are you using? This works correctly for me, using 2020.3 update.
Can you post your drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
ulgena
Thanks for your reply,
i am also using 2020.3 version.
tcorey
That's quite a project site.
To the question, using the Materials command/dialog, edit your render material and then edit the image. Change the sample size to something smaller.
Tim Corey
Redding, CA
ulgena
I tried it before. It only effects surface rendering. i was wondering abaout maybe it because of graphic card but i tried it in another pc with 12 core and nvidia rtx 2060 super graphic card but its still same.  Does it work in your computer?
