RealDWG 2018 crashed at around readDwgFile() function
We have developed an RealDWG-based host application for reading the DWG files.
It has been working fine with RealDWG 2017.
Recently, we have upgraded to the RealDWG 2018 and have encountered one crash that is always 100% reproducible as follows.
For the first time of opening/reading the DWG file, our RealDWG host application works fine.
However, after the first time, if we close the DWG file and then reopen it again (or open any other DWG file), the crash occurs
somewhere inside AcDbHostApplicationServices.
Please see the below call stack obtained by using ProcessHacker:
13, clr.dll!CorExeMain+0x108eb
14, clr.dll!CorExeMain+0xedc5
15, clr.dll!NGenCreateNGenWorker+0x1e1c
16, mscoreei.dll!GetXMLObject+0x727d
17, mscoree.dll!CorExitProcess+0x10d
18, ucrtbase.dll!wassert+0x40d
19, ucrtbase.dll!wassert+0x1e5
20, acdb22.dll!AcDbHostApplicationServices::fatalError+0x41
21, ac1st22.dll!AcRxIterator::isA+0x4b
22, ac1st22.dll!acrx_abort+0xab
23, ac1st22.dll!AcRxOverrule::isOverruling+0xd392
24, ac1st22.dll!newAcRxClass+0x64
25, ac1st22.dll!newAcRxClass+0x51
26, ac1st22.dll!newAcRxClass+0x37
27, AecBase.dbx!Ordinal2286+0x61
28, AecBase.dbx!Ordinal10623+0x5f8
29, AecBase.dbx!Ordinal10623+0x5e4
30, AecBase.dbx!Ordinal10623+0x7dd
31, AecBase.dbx!dxfNotSupportedMessage+0x8061
32, AecBase.dbx!Ordinal904+0x6db
33, acdb22.dll!AcDbUndoEdReactor::addDatabase+0x24f
34, acpal.dll!Autodesk::AutoCAD::PAL::FontUtils::getFontMetrics+0x1e37
35, acdb22.dll!acdbiEventLog+0x43e
36, acdb22.dll!AcRxImpDynamicLinker::sendAppMessage+0xcf
37, acdb22.dll!AcRxImpDynamicLinker::loadModule+0x138
38, acdb22.dll!AcRxImpDynamicLinker::loadApp+0x18b
39, acdb22.dll!AcRxImpDynamicLinker::loadApp+0xcb
40, AecBase.dbx!Ordinal904+0x331
41, AecBase.dbx!Ordinal904+0x6b7
42, acdb22.dll!AcDbUndoEdReactor::addDatabase+0x24f
43, acpal.dll!Autodesk::AutoCAD::PAL::FontUtils::getFontMetrics+0x1e37
44, acdb22.dll!acdbiEventLog+0x43e
45, acdb22.dll!AcRxImpDynamicLinker::sendAppMessage+0xcf
46, acdb22.dll!AcRxImpDynamicLinker::loadModule+0x138
47, AeccModuleLoader.dbx+0x210b
48, acdb22.dll!AcDbUndoEdReactor::addDatabase+0x24f
49, acpal.dll!Autodesk::AutoCAD::PAL::FontUtils::getFontMetrics+0x1e37
50, acdb22.dll!acdbiEventLog+0x43e
51, acdb22.dll!AcRxImpDynamicLinker::sendAppMessage+0xcf
52, acdb22.dll!AcRxImpDynamicLinker::loadModule+0x138
53, acdb22.dll!AcRxImpDynamicLinker::loadApp+0x18b
54, acdb22.dll!AcRxImpDynamicLinker::loadApp+0xcb
55, acdb22.dll!AcRxClassDictionary::getIDfor+0x4ac
56, acdb22.dll!AcRxClassDictionary::classInfo+0x3f0
57, acdb22.dll!AcDbImpDatabase::endDeepClone+0xd7d
58, acdb22.dll!AcDbImpDatabase::incrementalSaveAs+0x1bec
59, acdb22.dll!AcDbImpUndoController::isUndoAvailable+0x20b0
60, acdb22.dll!AcDbDatabase::readDwgFile+0x8d
61, 0x7feb89e38d7
62, 0x48d7b8
I suspect also call stack corruption, because 61 & 62 are not resolved function pointers.
Please be noted that if removing the AecModeler.dbx (so that it cannot be loaded) from the RealDwg2018, then this crash never occurs.
However, without AecModeler.dbx, it's impossible to handle the Cvil3D entities inside DWG file.
Any suggestion/help would be much appreciated.
Tarmo and Trung
moogalm
Autodesk Support
Autodesk Support
Please share the information how it can be recreated at our end.
Information like, steps to reproduce the behavior, a sample c3d drawing.
Can this be reproducible in dumpdwg sample? or is it specific to your environment.
If it is specific to your environment, please let us know how to create such environment.
Without having reproducible steps, it is difficult for us to troubleshoot the problem.
Thank you.
Note: Don’t share any confidential information.
In addition that :
OE 2018 installs files and registries to fixed location.
File: C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2018.1 Object Enabler 64 Bit
Registry: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\ObjectDBX\R22.0
RealDWG is always loading .dbx from above registry key. In theory, OE 2018 is available for all RealDWG application (with consistent version), We only verified the official target products (AutoCAD and family, InfraWorks, Navisworks Manager and simulation).
