Re-Writing Rectangle Linework Code Set
mburkeTJ54M
Observer
Observer
mburkeTJ54M
Observer
Observer
When importing 3 points that will be drawn as a rectangle, Civil3D reads the 'R' command on the 3rd shot.  Trimble Access is the opposite; the 'R' command is your first shot.  The end game here is to have the collectors and civil both draw the linework in the same fashion, but I don't see how to create a new action in the feature library in Trimble Business Center, so my hope is to re-write the code in the F2F_XDEF file for the linework code set in civil.  Does anyone know what code should be entered in the F2F_XDEF file to make civil read the rectangle command on the first shot, instead of the last?
This is the code currently in the F2F_XDEF file for a rectangle:  <kRectangle>R</kRectangle>
tcorey
What if you move the R to after the second kRectangle? or before the first. Move it around and see what happens. You can always put it back.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
