Announcements
"Plot transparency" causes aerial not to plot
Peter.NguyenUPHMM
Peter.NguyenUPHMM
Every year, my organization provides new aerials (.ecw files) for us to use. With my projects, I use MAPIINSERT to attach the aerials on a layer with a Layer Transparency value of 50. Once I've completed my project in paper space, I plot with "Plot transparency" checked. With this year's aerials, however, my aerials don't plot with the "Plot transparency" selection checked, using different plotting options to verify (e.g. print, PDFs, various .pc3's). This year's segmented aerials are each about 100 mb larger than the previous year's. I've tried changing the Raster Graphics to "Lower resolution," and increasing RASTERTHRESHOLD and RASTERPERCENT to max, but these didn't work either. Does anyone know any workarounds for this issue? Using Civil 3D 2023.
Replies (7)
Mike.M.Carlson
I see this behavior too. Civil 3D doesn't seem to honor the transparency band in .ecw files. The only workaround I found that works is to create an image clipping boundary using a closed polyline around the RGB and transparent edges.
It pains me to offer the work-a-round above but .ecw (despite being such amazing compression tech) is not fully supported in Civil 3D. They don't even support .ecw v3 file format yet.
I can say I even reached out to Hexagon support recently and we tried every possible method to export from GeoCompressor with various combinations of settings and Civil 3D just doesn't like .ecw transparency settings. I will say OpenRoads Designer and ArcGIS Pro had no problem with any of the .ecw files and they accept the latest .ecw v3 format. Sigh....
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
ChicagoLooper
Hi @Peter.NguyenUPHMM
This sounds like your ecw is a 4 channel multiband raster. Civil3D/Map3D only support 3 channels, such as RGB.
If you or your coworkers have access to third party software, e.g., Arc Pro, Global Mapper, QGIS, etc. etc. etc., you can use it to export the ecw to another format. AutoCAD friendly formats include tiff, jp2000, jpg, to name a few.
You may also ask the supplier of the rasters if they offer the same (or similar) image in another format. This will save you the time from performing the conversion yourself.
Chicagolooper
Mike.M.Carlson
I can apply transparency (4 band) in ortho imagery all the time in C3D (tif, png, jpg)…just ecw gets messed up somehow for me.
Michael M. Carlson
CADD Manager
Peter.NguyenUPHMM
Mike,
Do you happen to have an example of using the image clipping boundary? I usually clip my aerials by selecting the corners, but not typically using CLIP -> POLYLINE. Should I just make it the shape of my viewport? And how do I separate the RGB and transparent edges?
Peter
Mike.M.Carlson
no example, but I can walk through steps 🙂
  1. draw a poly line around the limits of RGB / Band 4 interface
  2. select image and in contextual Ribbon, look for Clip Image
  3. at command line select poly line object and select your polyline
this clips out the ;th band regions that are not honored in C3D for .ecw
Michael M. Carlson
CADD Manager
Peter.NguyenUPHMM
When I do this, my whole .ecw disappears (rather than simply clipping outside the boundaries of the polyline).
Mike.M.Carlson
Please select Invert Clip at command line. maybe your default settings are backwords.
Michael M. Carlson
CADD Manager
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
