Quickest way to remove vertices from polyline
ralstogj
ralstogj
Hi
I am wanting to know if there is a quick way to remove multpile vertice between two selected vertices
instead of the pe command and straighten?
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Replies (28)
ralstogj
Answer my own question again
Weedfeatures->Partial select the start and end point between where you want to weed set the settings to just length and some large value and the line will straight.
I bit tricker if the start and end point of the polyline are with the section being straightene as you have to do in two steps.
up to that point then remove manually.
Regards
Justin Ralston
Joe-Bouza
Map work space>>> Tools>>> cleanup. can go automatic or interactive
Joe Bouza
Neilw_05
Sometimes it's easier to just break it at 2 points, delete the unwanted piece and add a new one.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
ralstogj
Yep
Break and then close the pline would be quicker
Regards
Justin Ralston
neilyj666
Is the MAPCLEAN > WEED only applicable to 3D polys??
If reducing the number of vertices in 2D/contours then I use a lisp which does it for me......
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Joe-Bouza
Correct. Use simplify objects for 2d
Joe Bouza
jmayo-EE
Either can be used on 2d or 3d plines depending on what you want. Simplify will oonly delete colinear pi's. Weed may delete this pi depending on the angle setting and can change the direction of a course. I would most likely use weed on contour lines and I would simplify something like a curbline.
John Mayo
Dylandavid
Very Easy!
command:                 DeleteFeaturePI
Ribbon:                      ModifyTab->EditGeometry->DeletePI
HelpFile description:   Deletes a selected vertex on a feature line, survey figure, polyline, or 3D polyline.
Available in C3D, not sure about other versions.
WOW! DeleteFeatuePI worked perfect! Never heard of it before and this will help a ton!
THANK YOU!
the lisp super useful ****. Great thanks from hong kong user
neilyj666
Great - please feel free to give Kudos...:)
OMG YOU ARE ALL SOOOOO VERY
JUST FLOAT YOUR CURSOR OVER THE VERTEX A WINDOW POPS UP GIVING YOU THE OPTION TO REMOVE VERTEX
THEN YOU REMOVE THE VERTEX!!!!
HONESTLY
Of course that is possible and quicker than most options but I dont want to spend an hour deleting over 500 vertices from a line by hovering each vertex and waiting a second of two for the window to pop up.
jmayo-EE
And if you have a handful or so to delete the Delete PI command is faster than hitting the menu at ever vertex. But for one or two, yes the autocad command works great.
John Mayo
Johanyak
select the polyline , move your cursor to the vertex you wish to delete. A menu should appear and select remove vertex.
hello all
you can use the PEDIT command and yes, it does work for 3D polylines (at least in 2018)
select the pline and move along the vertices to the start of the section to be straighten, enter S (straighten) and then next to move to the next vertice,
continue along the pline to the end of the section to be strainghten and enter G for go, and the vertices between the start and end points are gone.
Works very well for changing small plines and holds the elevation for the start and end point on a 3d polyline.
nonbeard13
Nonbeard13,
That is a great new feature that I never know about!
Thanks for sharing.
tcorey
The OP said he/she wanted options other than this one, but it's still my favorite. It gives you direct control of where to straighten and takes seconds.
The sad thing is that so few newer (and even many very experienced) users even know about PEDIT. Anyone who is a curious AutoCAD user should explore this command.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
neilyj666
It is still a bit painful if you have many vertices and the first one is many clicks from the start (as is the final one)....
