Quick way to insert degree symbol
Message 1 of 8
What is the fastest or your preferred way of inserting the degree symbol using the standard terramodel text command?
Replies (7)
Message 2 of 8
TerryDotson
This isn't TerraModel, but between %%d and Alt+248 (hold down the Alt key while type 248 on the number pad, then release) you should be able to add a degree symbol.
Message 3 of 8
They both work in Terramodel. Thanks Terry
Message 4 of 8
There is actually another shortcut, press ctrl+backspace.  It inserts a degree symbol, and is only a combination of two keys, therefore it is what I like to use.
Oh, and I know this works in Terramodel, because that is the program I work in.  Anything else, I wouldn't know...
Message 5 of 8
We can say that the degree symbol is a kind of typographic symbol. This symbol is used to represent degrees in many different fields, such as angle or temperatures. It is obtained by drawing a small circle as a superscript. The Unicode of the icon is U + 00B0. With the latest developments of modern technology, many different online systems and softwares are used in our daily life routines.
DEGREE SYMBOL: °
Message 6 of 8
AllenJessup
Also Alt+241 is ±.
Allen Jessup
CAD Manager - Designer
Message 7 of 8
ChicagoLooper
Alt+0176
Chicagolooper
Message 8 of 8
mieczotronix
I've just found you can type "deg" instead
