- Mute
- Permalink
- Report
Possibly a silly question...so my problem is I want to see two different surfaces elevations at the same time (EG and the PG), both of these surfaces are external referenced into my drawing.
I thought in the past I have done this with no problem. But in my dwg with xref's I can not get the elevation tooltips to come up when hovering over my surface(s). If I open up my basefile where the surface is located then I get those tooltips no problem. I have tried to use the INQUIRY tool and the tool will not work on the drawing with the xref's, it says its Z coordinate is non-existent. But using the inquiry tool in the basefile works fine.
I'm pretty new to Civil3D so if this is a thing that is not possible and I thought I remembered it before I apologize. So is this possible to do with surfaces that are xref'd? The engineer is wanting to see both our Existing elevation and the Proposed elevation at a certain point within the surfaces at the same time. Thank you so much!
This is the tooltip I want to see for both of my surfaces..
