Civil 3D Forum
Publishing PDF's in Civil 3D 2014
7 REPLIES 7
Message 1 of 8
jeffl
1340 Views, 7 Replies
Has anyone else noticed that the file size of pdf's created using the publish command in C3D 2014 are much larger than files created using 2013? I'm talking twice the size in some cases. I've gone through the settings and found no differences, but there must be something I'm missing. When I use the plot command on a single layout, the file sizes are similar, so there must be something in the publish command. Any ideas?
Jeff Leeman, C.E.T.
7 REPLIES 7
Message 2 of 8
Jay_B
in reply to: jeffl
Take a look at the Dpi setting within the Dwg to Pdf.pc3 file being used with the Plotter configuration Editor.
(Right click on pc3 in Win explorer>open) is one way to get to plotter config edit. Device and Document Settings tab>Dwg to Pdf.pc3>Graphics>Custom Properties>Access Custom dialog>Custom Properties button>The higher the dpi setting the larger the file created. We have ours all set at 400 and print quality is good here.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 8
jeffl
in reply to: Jay_B
Thanks for the suggestion, but I already have checked that. My settings for 2013 & 2014 dwg to pdf.pc3 are identical. We use 600dpi.
With the use of ftp sites for file transfer, I'm more curious as to the reason than concerned about file size.
Sincerely,
MERITECH ENGINEERING
Jeff Leeman, C.E.T.
Senior CAD Designer
Meritech Engineering
1315 Bishop Street North, Suite 202
Cambridge ON N1R 6Z2
t 519.623.1140 x216
f 519.623.7334
www.meritech.ca
CAUTION: This message is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged, confidential and exempt from disclosure under applicable law. If the reader of this message is not the intended recipient or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify the sender by return e-mail.
Jeff Leeman, C.E.T.
Message 4 of 8
ToddRogers-WPM
in reply to: jeffl
Hotfix 1 installed?
Todd Rogers
Message 5 of 8
in reply to: ToddRogers-WPM
What about layers, autocad can create pdf's with and without layers that can be turned on and off?
Message 6 of 8
Lisa_Pohlmeyer
in reply to: jeffl
I just checked the difference between 2012 and 2014. The Dwg2PDF.pc3 files are the same, the PDF size is very slightly different.  2012=239kb and 2014=226kb.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 7 of 8
jeffl
in reply to: Lisa_Pohlmeyer
Thanks to all who have responded to this post.  I appreciate the suggestions.
My dpi settings and layer settings are identical between the two versions of C3D.
I do recall the pdf file size being reduced from 2012 to 2013, so I wonder if Autodesk has undone whatever they did to reduce file size for some reason??
Jeff Leeman, C.E.T.
Message 8 of 8
dhenderhan
in reply to: jeffl
I myself havn't really noticed a huge difference in file size, but the print process definately takes much longer from 2014 than it did from 2013.  It shouldn't be the pc3 file, I repathed to the same pc3 file for both versions.
David E. Henderhan, PLS
Civil 3D 2025
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
Rail Community
