Announcements
Provile view style
Provile view style
Hello! I want to make "the profile vertical scale 1 inch = 5 feet". Did I make it right? See photo attached.
cwr-pae
With the horizontal scale at 250 your 5 vertical exaggeration gives a vertical scale of 1 unit = 50 (1:50) For 1:5 you should use a vertical exaggeration of 50. The way to determine what to use is horizontal scale over desired vertical scale: 250/5=50, there for use vertical exaggeration of 50 for 1" to 5'
Hi
did you drawing units in feet or meter?
if it is in feet it should appear like photo attached
