Civil 3D Forum
Proposed surface from Point & Link codes
1 REPLY 1
aniket.bhola
174 Views, 1 Reply
Hi everyone,
I am working with Civil 3D subassembly composer to develop typical cross sectional element details as per project requirement. I have established different point code and link codes to all elements as per requirements (sample shown in Image 02).
Developed subassemblies I am using to generate corridor model and finished (proposed) surface. To generate finished surface from corridor model; every required link & point codes added from add surface tab but not getting proper surface at Red highlighted region in the Image 03.
Is there any method to solve this issue using point & link codes or by any other methods.
Thank you
-Aniket
1 REPLY 1
Udo_Huebner
in reply to: aniket.bhola
The sub-assembly and profile might be fine for a correct volume calculation. This cannot be assessed without a PKT file. The limitation is the DTM surface, as 2 or more elevations (Z values) for the same location (X-Y position) are not allowed.
As a workaround, you need to create multiple surfaces for the overlapping areas.
Gruß Udo Hübner (CAD-Huebner)
Rail Community
