So I thought I'd get to learn Property Sets and started with a simple drawing. I have been biking lately and drew some polylines of my routes, created a Property Set with a description, date, name1, name2, and a calculation of converting the length from feet to miles. There's 11 polylines with the Property Set data attached and now I want to either create a simple table in the drawing that lists the Property Set data or export it to an Excel file. Sounds like a basic use of Property Sets, but that seems to be way more difficult than it should be. I've done some DuckDuckGo searches and YouTube searches about Property Sets, but nothing really explains what to do with the data once added to an object. Everything I've found is about adding Property Set data to a specific C3D object label type, such as a fitting, and getting a fitting label to reference it. Nothing about how to make a table or export of the Property Set data that's on a non-C3D object type.
This leads me to wonder: What's the purpose of Property Sets if they're so limited? I thought Property Sets would be a way to add custom object data and the ability to create reports, tables, etc. of that data. Seems if that's possible, Autodesk needs to do a much better job of explaining it as I've scoured the interwebs and see no real solution nor purpose for Property Sets.
Windows 11
32GB RAM
