Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Property Set Data
2 REPLIES 2
apweng
540 Views, 2 Replies
Property Set Data
Hi there I have a few questions relating to Property Set Data for C3D Objects (Pipes and Structures)
Where can I find a complete list of properties that I can extract using formula?  As a starter I would like to copy the object name to property data sets.  This is all I can find...
http://blog.civil3dreminders.com/2016/03/freaking-context-values.html
Also - I'm curious if there is a way to select objects in a drawing based on Property Set Data queries.  I have done this with object data but not sure about property set data.
Thanks!
Andrew
2 REPLIES 2
drazen.galic
in reply to: apweng
Hi @apweng,
I was looking for the list of all properties which can be used for automatic generation of property set values some months ago and then Peter Engels from Autodesk gave me the next link:
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXPipeLib__IAeccPipe.htm?_ga=2.82...
 Think that here you have all available properties.
Regarding query of objects with certain values of property set data. As far as I understand it is not possible OOTB in Civil. You need additional application for that. Map can query object data, but unfortunately not property set data.
Drazen
If that post solves your problem press Accept as solution
Is it still just an great idea?
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Rail Community
