Property Set Data : Fetching the Inverts at the beggining and ending of a pipe with 3 decimals, how ?
cyberflow
Advisor Advisor
cyberflow
Hi all,
I've been trying to make this work with 3 digits but it seems not to be working by adding a round() into it but the information contains only 2 decimals ...
How can we format this line so it outputs 3 decimals ?
spos = aec.ActiveDocument.Utility.ConvertToVariantArray(obj.PointAtParam(1))
FYI here's the VB scripts :
Property set data VB script for Inlet Invert (Return 2 decimals) :
RESULT = "--"
On Error Resume Next
Set oApp = GetObject(, "AutoCAD.Application")
Set oCivilApp = oApp.GetInterfaceObject("AeccXUiPipe.AeccPipeApplication.13.5")
Set aec = oApp.GetInterfaceObject("AecX.AecBaseApplication.8.5")
aec.Init oApp
Set obj = oCivilApp.ActiveDocument.HandleToObject("[Handle]")
spos = aec.ActiveDocument.Utility.ConvertToVariantArray(obj.PointAtParam(0))
RESULT = round(spos(2),3)
Property set data for Oulet Invert (Return 2 decimals) :
RESULT = "--"
aec.Init oApp
RESULT = spos(2)
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Accepted solutions (3)
cyberflow
I just noticed something :
The code in the property set data sends out incorrect inverts :
The correct inverts :
The inverts returned from the property set data VB Scripts :
Is it normal ?
Frank Freitas
LinkedIn
lim.wendy
Hi Frank,
Thank you for submitting your question in our discussion forums.
Have you tried adjusting the precision from the Property Data Style Manager?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
cyberflow
Hi @lim.wendy  !
Thx for answering !
That seems pretty neat but i wonder why it doesn't give the correct invert ?
RadierDebut = Start Invert
RadierFin = End Invert
I feel like it's giving the centerline Z of the vertice ?
Frank Freitas
LinkedIn
cyberflow
Start invert VBscript :
RESULT = "--"
Set oCivilApp = oApp.GetInterfaceObject("AeccXUiPipe.AeccPipeApplication.13.6")
Set aec = oApp.GetInterfaceObject("AecX.AecBaseApplication.8.6")
aec.Init oApp
RESULT = spos(2)
End invert VBscript :
RESULT = "--"
aec.Init oApp
RESULT = spos(2)
Frank Freitas
LinkedIn
Jeff_M
It is. You will need to get the InnerHeight and subtract 1/2 of that from the Z obtained.
Jeff_M, also a frequent Swamper
cyberflow
Hey hi @Jeff_M
This did work :
End Invert :
RESULT = "--"
aec.Init oApp
RESULT = FormatNumber(spos(2) - (obj.InnerHeight / 2), 3)
Start Invert :
RESULT = "--"
aec.Init oApp
Thanx again folks to helping someone out - I let the code here for someone else to use in the futur.
Usefull link :
http://docs.autodesk.com/CIV3D/2013/ENU/API_Reference_Guide/html/73fd1950-ee31-00b8-4872-c3f328ea133...
Frank Freitas
LinkedIn
