ProjectWise and Custom Profiles
seanp.fahey
seanp.fahey
I have created a custom Civil 3D profile that has support folder paths pointing to our linetypes, plot styles, templates, etc., Civil 3D 2023.3.1.
We utilize ProjectWise for our projects (for time being) and when I export the profile for other users to use I receive this error.
I am not sure what this error is focused on.  When I hit yes I get a message saying it wasn't able to include the variables and instead skipped the variables.  Is there something within custom profiles that ProjectWise is not able to understand?
Bottom line is, is this an Autodesk issue with exporting custom profiles that has ProjectWise integration or is this a Bentley issue?
Thank you
rl_jackson
@Joe-Bouza might be able to assist with this one.
Rick Jackson
Survey CAD Technician VI
Joe-Bouza
You are exporting an ARG file that contains search paths that may include PW. I'm guessing it more FYI then anything fatal.
I would check that all the other users share the same PW search paths. If not probably dont want to share the ARG
Joe Bouza
v-silvestre
I think this is more of a Bentley > ProjectWise Integration thing.  Even exporting the OOTB <<C3D_Imperial>> profile gives the same warning message:
Michael_McKeon
If you edit the ARG, and search for your ProjectWise working directory, it is likely being called in the ARG. I have been able to remove those entries from the ARG to get rid of the error.
