Projections updated in old drawing each time it's opened
AllenJessup
Mentor Mentor
AllenJessup
I get the following mesage in the Panorama each time I open the drawing.
"Following AutoCAD solid projections have been updated as the drawing was edited using an earlier Civil 3D version :
Sphere- 2".
I'd think if it was updated the update would be saved with the drawing. But obviously not. This doesn't seem to be a huge issue. But, I have to clear the events and close the Panorama each time.
Allen Jessup
CAD Manager - Designer
CodeDing
@AllenJessup ,
Maybe you could:
- Remove current Coord Sys
- Save & Close dwg
- Open dwg and re-assign Coord Sys
- Save new Coord Sys
Idk, worth a try
Best,
~DD
AllenJessup
@CodeDing I don't think it has anything to do with the coordinate system. I believe it's a Sphere I projected on to the profile as a marker.
"Following AutoCAD solid projections have been updated as the drawing was edited using an earlier Civil 3D version :Sphere- 2"
Allen Jessup
RobertEVs
If you are wanting to remove it, have you tried quick select > Object type > find the object > operator= Select All. Then delete it once selected.
AllenJessup
I decided I should do that rather than enjoying being annoyed with the program. I'll see what happens next time I open the drawing.
Allen Jessup
AllenJessup
I erased 2 projected spheres. Still get the message on opening. BTW They were projected into Section Views not Profiles.
Allen Jessup
