Civil 3D Forum
Projected Objects xref not displaying
3 REPLIES 3
dosheaA9EUT
760 Views, 3 Replies
I xrefffed cross sections that are contained in drawing A into drawing B. Drawing A contains projected objects (feature lines) in the cross sections. The cross section display in drawing B but the projected objects do not. The layers are on in both drawings. Is there a setting I am missing or something else ?
3 REPLIES 3
@dosheaA9EUT ,
This is a great question, welcome to the Civil 3D forums. I wonder if you have files you can post that have this behavior exhibited in them? I want to say that I think you may be overlooking a profile style display setting as seen like in the photo I am attaching. Try "toggling" some of these objects in your section style in both drawings to see what definition control you could gain. Please hit the Accept as Solution button if a post fully solves the issue or answers the question.​ Thank you for your participation, your accepting a solution adds value to the post for the community as a whole, and helps other members find answers to their issues.
Copper Chadwick
Designated Support Specialist
@dosheaA9EUT ,
I was checking back to see if you found useful my reply to you original post. Please hit the Accept as Solution button if a post fully solves the issue or answers the question.​ Thank you for your participation, your accepting a solution adds value to the post for the community as a whole, and helps other members find answers to their issues.
Copper Chadwick
I found a solution. I had to detach then attach the xref again. It would not update the xref and include the projected objects.
Rail Community
