Project Objects to Multiple Section View Label Default Settings
RayM2305
RayM2305
When I project my feature lines titled "ROW (L)" and "ROW (R) to multiple section views, the markers shows up showing the Offset and Elevation labels instead of showing as what I called the feature lines. So, I would have to go through every single label and "Edit Text Label" and change it to use Source Name instead.
I know under Setttings, Section View, Commands, ProjectObjectsToMultiSect option but I don't know how to set it so that the label uses the Source Name by default instead of Offset and Elevation. Or is it located in another settings option?
Anyone know how I can change this so that I can set it in my drawing template to use Source Name as the default?
JDB423
If you right click 'section view' and edit feature settings, navigate to the default styles and look for 'Section Crossing Label Style', you can then choose/edit a style to use source object name instead.
Hope this helps
RayM2305
Thank you! That solved it for me.
