Civil 3D Forum
Project object in section
1 REPLY 1
187 Views, 1 Reply
I am trying to project some solids in section. So far That I was using Civil 3D 2012 had no problem but since yesturday which I started using 2014. In some cases when I used slice on a solid it showed elevetion 0 in section and in one case it just can't get the elevation of the solid while it has an elevation but still it showes 0 for elevation. Is it a bug or I should do something different in 2014?
1 REPLY 1
Does your solids got an elavtion? If non, you can set its elevation under the ELEVATION OPTION column to MANUAL or use an elvation from your surface. Cheers.
Rail Community
