Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Profile view section name Band
11 REPLIES 11
Message 1 of 12
khaledCULN8
1214 Views, 11 Replies
I'm having trouble creating a band style with custom section names.
for example: i created a custome section name label. 2000 as starting point - Index every 20 (m).
i need to make the same thing in the profile view for my profile in order to match the section names i created for the Alignment. for now, i've done it manually. but i'm sure there is a better way to do that.
see the attached photo for the section names for the alignmnet that i created using expressions.
also another photo for section names in the profile view that icreated manually.
can anybody help my figure that out?
thank you in advance
KhaledAlignment Label created using expressionsAlignment Label created using expressionsProfile band created manuallyProfile band created manually
11 REPLIES 11
Message 2 of 12
Neil.Aryan
in reply to: khaledCULN8
@khaledCULN8,
I assume that on the profile view where you added/placed the stations are in cyan color (at last most values) which dosnt match with alignment station image, can you correct me if i am wrong? ans also share the dwg file only with the alignment with the stations which you want to show on the profile so that can check and find the solution.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Project Manager | Civil | ACE Inc.
Certified Civil 3d Professional | YouTube | My-Blog
Message 3 of 12
Unfortunately the profile view band labels cannot use expressions so you have to either work with profile labels or change your alignment start station and set up the labels as below.
If you change your major labeling format to station, you can set the station label to station format with a station character of none and output of left of the station. Then just set the major station label spacing to what you need. This will show the format you want then you only need to set the start station of the alignment in the alignment properties.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Message 4 of 12
lynn_zhang
Hello @khaledCULN8 ,
Just checking to see if your problem has been solved. Did the response from @Neil.Aryan and @andrewpuller3811 help answer your questions? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Message 5 of 12
andrew,
first of all, thank you for your response.
2nd of all, i attached a link to download a dwg file.
the dwg file contains an alignment that has a custome section name label. 100 as starting point - Index every 20 (m).
can you please show me an example using the file i attached?
thank you in advance,
DWG File
khaled
Message 6 of 12
khaledCULN8
in reply to: Neil.Aryan
Neil,
i attached a link to download the DWG file.
the dwg file contains a custom station label. 100 as starting point - index every 20 (m).
i need to create a profile band with section names that match with labels created for the alignment.
DWG File
khaled
Message 7 of 12
udo.huebner
You have not created any sample lines yet.
Instead, the labels of the section names are created from the alignment using main station labeling with custom expressions.
Why not add a real Sample line group? You can use an invisible style for the sample lines if desired.
Then add Band Type "Sectional Data" Style "ISR Section Name INDEX" to your profile View > Bands and the band labeling is as intended.
Message 8 of 12
khaledCULN8
in reply to: udo.huebner
hi,
i didn't understood completely your explanation.
can you show me an example?
khaled
Message 9 of 12
udo.huebner
@khaledCULN8  Hello Khaled, using your sample file I recorded a Screencast to explain more clearly my given suggestion on how to create a sample line group and add the Section numbers to the Profile view band then. I hope this is what you are looking for.
Civil Alignment Sample Line Group with Section numbering in Profile View Band, is ready for viewing.
Message 10 of 12
khaledCULN8
yeah, that's the way do it
much appreciation @udo.huebner
khaled
Message 11 of 12
khaledCULN8
hi,
is there a way to do the same thing with the section view names?
@udo.huebner
khaled
Message 12 of 12
udo.huebner
Not directly.
But the Section View names can be built using the Properties "Next Counter", "Parent Alignment" and "Section View Station" in Name template.
Using "Profile (<[Next Counter(CP)]>)" as name template and the starting number is set to 100 this will produce Profile View names matching to Section Lines names.
Rail Community
